1987 Volvo 240 Repair Question
Topics covered: Fuel pump, Compression, Engine.
Asked on November 8, 2010
1987 Volvo 240
1987 Volvo 240
car starts and shuts back off, won't idle. fuel pump runs, has gas, has ignition, fuel injector spray, spark plugs fire, changed fuel pump relay, has engine compression and cam timing is good.
Answer
Replied on November 8, 2010
CLASSIC MASS AIR FLOW SENSOR SYMPTUMS; HOWEVER, YOU SHOULD TRY REPLACING THE SUPPRESSION RELAY FIRST AND THEN SEE WHAT HAPPENS.
