1985 Volkswagen Van Repair Question
Topics covered: Engine, Oil pressure, Mechanic.
Asked on May 29, 2009
1985 Volkswagen Van Oil pressure warning light
Engine Mechanical problem
1985 Volkswagen Van 4 cyl Two Wheel Drive Manual 198000 miles
Oil pressure warning light comes on a low idle. It goes out when driving but comes on again when I stop at light and the engine RPM's decreases.
The owners repair manual says you should not drive the car when this occurs.
Answer
Replied on May 29, 2009
Check the oil pressure with a mechanical gauge if normal replace the oil pressure switch abnormal could be the oil pump or engine bearings
