2CarPros - Car Questions & Answers
1985 Volkswagen Van Repair Question
Topics covered: Axle, Cv joint, Grease.
Asked on August 3, 2009
Cv boot replacement
Drive Train Axles Bearings problem
1985 Volkswagen Van 4 cyl Two Wheel Drive Manual
I have VW based sandrail with a 3-rib bus IRS transaxle. I need to replace an inner cv joint boot. How is this done? Chuck
Avatar Asked by Cestill
Answer
Replied on August 4, 2009
first of all you will have to remove the axle, once you have it off on the very end there is a C clip that will need to be removed and the whole CV joint will come off with the boot, remove the boot replace, make sure the job goes back together with new Grease.
Tiny Answered by Dr Loot (expert)
2,176 answers provided
