2CarPros - Car Questions & Answers
2001 Volkswagen Jetta Repair Question
Topics covered: Engine, Mechanic, Timing belt.
Asked on April 2, 2009
Timing belt
Engine Mechanical problem
2001 Volkswagen Jetta 4 cyl Two Wheel Drive Manual 120000 miles
I had a mechanic take a look at it. He tells me the timing belt needs to be replaced plus the valves are probably damaged?
Are these two related and if so, do both need to be replace/fixed for car to run properly. My engine light is also on?
Avatar Asked by lp69777
Answer
Replied on April 2, 2009
If your vehicle is equipped with an interferrence engine and the timing belt is damaged/loose then this will cause valve damage as well. You will need both replaced or further damage will occur resulting in having to replace the engine or have it completely rebuilt. Need to have diagnostic trouble codes scanned to see why the engine code is illuminated.
Thanks for using 2CarPros.com!
Tiny Answered by bluelightnin6 (expert)
17,236 answers provided
