Mechanics
VIBRATION
1995 Ford Taurus • 117,000 miles
I just bought a ford taurus gl 95 and it pulls to the right and vibrates what is causing this
Tigerjaxson
April 29, 2013.
A bad tire is the most likely cause. Examine the tires closely while spinning them to look for radical movement. You could also rotate front to rear to see if the pull stops to indicate a bad tire also.
Wrenchtech
Apr 29, 2013.
AD
