2004 Vauxhall Zafira Repair Question
Asked on June 23, 2009
Front pad replacement
Brakes problem
2004 Vauxhall Zafira 4 cyl Two Wheel Drive Automatic
DO YOU HAVE ANY TIPS FOR CHANGING THE FRONT PADS? I HAVE CHANGED PADS ON OTHER CARS BUT THESE LOOK TO WORK IN A DIFFERENT WAY. IS THERE ANY ADJUSTMENTS TO DO OR IS IT A CASE OF TAKING OUT THE OLD AND PUTTING BACK NEW?
Answer
Replied on June 24, 2009
There are no adjustment's if you have replaced pads before this is exactly the same way ...
