1999 Vauxhall Tigra Repair Question
Topics covered: Coil pack, Crankshaft, Sensor.
Asked on June 24, 2009
1999 Vauxhall Tigra coil pack
Electrical problem
1999 Vauxhall Tigra 4 cyl Manual
i have no spark at numbers 1 & 4 cylinders, the plugs and leads are fine, would i be right in assuming that it could be the coil pack that is faulty
Answer
Replied on June 24, 2009
replace the coil pack ..also you could check and clean/replace the CKP (crankshaft position sensor)
