1994 Vauxhall Other Repair Question
Topics covered: Engine, Mechanic, Compression.
Asked on January 15, 2009
Models car cranks but will not start
Engine Mechanical problem
1994 Other Vauxhall Models 4 cyl Four Wheel Drive Automatic
I have a 2.0i engine. I just filled up with petrol and drove out of the garage I got about 200 yards down the road and car just stopped and we drifted, car would not start. Had to leave it there till we got it towed back home. When we did, we tried it again and still no luck.
When we crank, it sounds like the engine is turning quicker than it ever has.
We went through all standard tests, i.e. fuel pump, diagnostics, distributor, rotor arm, spark plugs, HT leads. Nothing!!
We then checked the cambelt and found it had broke. I understand that this can cause major mechanical problems with engines if they fail but we was only going at 20MPH if that. Anyway, replaced that as well and still no luck but engine is rotating a bit slower now. We don't know what to check next, can you help?
Answer
Replied on January 15, 2009
Do an engine compression tests and give me the readings, the valves could all be bent if its an interference engine
