1993 Vauxhall Other Repair Question
Topics covered: Coolant, Cooling fan, Engine.
Asked on May 31, 2010
Models cooling fan
Electrical problem
1993 Other Vauxhall Models 6 cyl Two Wheel Drive Automatic 141009 miles
For cooling i am using the electric air con fan on a direct switch circuit as the main viscous fan is not working . I have a 40 amp relay on this circuit but these burn out after about 4/6 weeks. What power relay should i use please?
Answer
Replied on May 31, 2010
not sure what model of Vauxhall you have but a 40 amp relay should not burn out that fast for the cooling fan. have you tested the engine coolant sensor as to why the fan does not run properly?
