2004 Vauxhall Astra
2004 VAUXHALL ASTRA
TOPSY
Engine Mechanical problem
2004 Vauxhall Astra 4 cyl Two Wheel Drive Manual
when engine running oil being sucked out of engine via rocker cover breather direct into inlet ports resultin in major oil smoking seems to be major vacumn fault dissconnect breather from rocker cover and block of engine runs perfect compressions all good no stored fault codes any ideas would be greatfull many thanks
Oct 12, 2008 at 1:56 PM
