2CarPros - Car Questions & Answers
1996 Vauxhall Astra Repair Question
Topics covered: Coolant, Engine, Battery.
Asked on December 19, 2009
1996 Vauxhall Astra frozen water pipes
Noises problem
1996 Vauxhall Astra 4 cyl Front Wheel Drive Manual 143150 miles
hi i have a vauxhall astra 1.4 expression my car as been stood for 2 weeks i had to have my battery jump started and it sounded like i was running on three plug but when i went to check the water it was full but the main water pipe that runs to the radiator and i think it also runs to the engine is frozen solid how do i un freeze it and is that why it is not running properly and sounds like im running on three plugs
Avatar Asked by michaelm86
Answer
Replied on December 22, 2009
Do no t run the vehicle again with frozen water in the hose's, chances are if the coolant in the hoses is frozen so is the coolant in the engine block .. you need to push the vehicle into a garage with a heater and thaw the car out before attempting to start again ?
Tiny Answered by Dave H (expert)
13,682 answers provided
