Mechanics
TRUCK STOPED RUNNING RIGHT .
1994 Chevrolet Blazer • 250,000 miles
My truck wont run correctly. I replace the throttle body the fuel lines fuel filter in the fuel pump. It will start and idle but it will not stay running when I give it gas it will die what else could I do to find out what the problem is
Capmemike
May 4, 2013.
Scan for codes and check fuel pressure first 9-11psi with tbi unit. Also check for a vacuum leak
Hmac300
May 4, 2013.
