Mechanics
OIL PRESSURE
1972 Triumph Spitfire
Engine Mechanical problem
1972 Triumph Spitfire 4 cyl Two Wheel Drive Manual
Have rebuilt engine and has great oil pressure if you spin the oil pump with drill, however the gear between distributor and oil pump doesn, t go down far enough to engage into the oil pump drive shaft. Have tried to install several times so I am convinced it is dropping as far as possible. The pin in the gear is OK and not sheared.
Any help appr.
Tspit
August 17, 2009.
Check out the related content below while we wait for the question to be answered by a professional mechanic.
AD
