1974 Triumph Other Repair Question
Asked on January 26, 2009
1974 Other Triumph Models
Electrical problem
1974 Other Triumph Models 6 cyl Two Wheel Drive Manual 85000 miles
Greetings, the ingnition system (coil) craps out after a few hours of driving. It gets very hot and dies. After a few hours to cool, everthing is fine. any ideas? Also; 40,000 V coil, non ballasted, connected to a Pretronix dizzy and a MSD 6AL (runs off the battery and gets hot also). Coil is mounted on the block (original location) should I move it to the firewall? When hot, no spark from the coil or the MSD unit. Suggestions are welcome. Thanks, John
Answer
Replied on January 26, 2009
Have you considered installing a current limiting resistor?
The reason the engineers install a ballast or current limiting resister is to defeat the issues you are claiming.
