Mechanics
TRANSMISSION OR REAR END?
1997 Ford Ranger • 140,000 miles
The other day I was going to leave my house, I out the truck in drive, but all it did was rev up. I have a loose shifter indicated so I figure I have just put it in neutral by mistake.I shifted down once again this putting the truck in 2nd gear. It reved for a sec, the went into gear, I got about a block and then it reved up again, and know it wont go into gear at all. I was wonder if you could help point me to the problem. Thanks
if you dont mind, can you give me a call 1(361)543-6387. It would help me out more, incase you have tips so I can be out side and not next to this computer
Mojo1195
April 13, 2013.
Beyond checking the fluid, it is internal failure from either the otrque converter or the front pump
AD
ASEMaster6371
Apr 13, 2013.
Thanks, I shall check that out tomarrow in the morning
Mojo1195
Apr 13, 2013.
AD
