Mechanics
TPS SENSOR
1996 Honda Accord • 232,000 miles
Hi sir
Today I check the voltages of the TPS sensor. At fully closed throttle the voltage is 0.39 V at the fully open the voltage is 3.41 V is this voltages are within specification. It was a smooth transition between 0.39 to 3.41. The reference wire is 4.99 V.
Thank you
Zemorzemor
May 3, 2013.
It's a little low on the wide open side but I wouldn't expect that to cause a problem. It may be by design.
Wrenchtech
May 3, 2013.
