1987 Toyota Van
Smells problem
1987 Toyota Van 4 cyl Two Wheel Drive Manual 155000 miles
Hi I have an '87 toyota van that has been sitting in the back yard for three years. When I parked it it did run, usually, but had problems with the starter, the alternater, the battery, the starter relay. The heat had not worked since I got it, but it is not a fan problem. The windshiled is cracked, also the front seat is not bolted down. Since I live in Michigan it is frozen to the ground. My buddies range rover could not get enough traction to pull it out so I could try to pop the clutch to see if it would fire right up like usual. Also the neighbors cats have been living in there for some time and have made my custom upholstry their litter box. So how can I have the cat sh!T smell out by the next thaw? So the rest is worth fixing. My 91 Safari that I bought for $300 and drove for 4 years blew its trans. Also, what should I do about all the other stuff wong?
February 16, 2010.
Check out the related content below while we wait for the question to be answered by a professional mechanic.
