Mechanics
INNER CRANKSHAFT PULLEY
1996 Toyota Tercel
Noises problem
1996 Toyota Tercel 4 cyl Two Wheel Drive Automatic 150 miles
the inner crankshaft pulley (the one that drives the alternator belt) is moving backand forth at times cause a load noise as it comes incontact with the outer pulley or the timing cover. Is there a way to tighten this? Are the two pulleys supposed to be pressed together? Thanks for any info, Doug
Mrbof3
November 22, 2008.
Check out the related content below while we wait for the question to be answered by a professional mechanic.
