Mechanics
OIL CONSUPTION
1994 Toyota Tercel
Engine Mechanical problem
1994 Toyota Tercel 4 cyl Two Wheel Drive Manual 200000 miles
i have toyota tercel 1994 recently I have problems with oil consumption, I have valve job done but problem persist, before one spark plug was coming up wet now the problem is correct but now is using a lot oil (1 qt per 60 miles aprox.) Is not oil leaks outside engine, sparks plugs are coming out dry, little smoke true the exaust, car is no loosing power, what else can I check?
Osnuher
April 4, 2009.
Check out the related content below while we wait for the question to be answered by a professional mechanic.
