Engine Revs up and down at idle
DAVEANDPATTY
  • 1993 TOYOTA TERCEL
Rebuilt engine, 26k miles. Stumped on this one. Engine pulses acceleration after warm up. Won't idel. This all started when I tried to clean throttle body and had removed; but reinstalled the linkage for throttle and stop sets for idle up. Tried to replace MAP sensor; but no luck. I think it has someting to do with the idle up sensor and/or MAP sensor. No "check engine" light comes on. Tried to adjust throttle positioner and idle set RPM's but still won't idle. Pulses up rpm's and then down. When I unplug the MAP sensor it will idle rough but will stop pulsing. Can someone help with this problem. I'm stumped.
Friday, April 27th, 2007 AT 11:37 PM
2CARPRO JACK
  • 11,533 POSTS
Sounds like there might be a vacuum leak. Did you replace the throttle body gasket? If you get the base idle adjustment too far off, the computer will fight it for control of idle.
Sunday, May 13th, 2007 AT 9:06 AM
DAVEANDPATTY
  • 8 POSTS
Thank you so much for an answer. Yes, I did replace all the gaskets; but that base idle set just may be the problem. I didn't think about reinstalling it to the original setting; because that mark got removed. I just screwed the linkage back to the body and hooked up the throttle cable. I'm going to try and reset it per the factory manual instructions. I'll post the results here. Thanks again for the help.
Sunday, May 13th, 2007 AT 9:43 PM
DAVEANDPATTY
  • 8 POSTS
I reset all the adjustments of the throttle positioner and the idle stop set to the factory specs. Engine still wants to rev up and down at idle. I tested the vacuum sensors and the throttle positioner and they test good. The engine will hold steady at around 2500 rpm's; but when you let back on the throttle to idle, that's when it starts to rev up and down by itself. I'm without a clue now. Can someone please help?
Wednesday, May 16th, 2007 AT 11:48 PM
Try the idle air control valve clean it-than fire it up now adjust the idle screw hidden under a rubber plug.
Thursday, May 17th, 2007 AT 2:42 AM
DAVEANDPATTY
  • 8 POSTS
I cleaned the air valve, the throttle body, the EGR valve body which had a little carbon build up, installed new gaskets; but engine still won't idle smooth. I checked the vacuum sensors and the vacuum switches, they all check out OK. I checked all the vacuum hoses for leaks and all were good. Engine still revs up and down all on it's own. 800rpm to 2700rpm then back to 800rpm. When I disconnect the vacuum switch for the fuel rail pressure reg the dash pot for the throttle positioner will start to pulse the throttle up and down. When I disconnect the MAP sensor the engine will idle rough and then die. It also will register a trouble code for the MAP sensor; but will clear out when I reset the ECU. So I think the MAP sensor is good. I actually replaced it a few days ago. I'm really stumped on this one. Can someone please help. Thank you.
Tuesday, May 22nd, 2007 AT 11:45 PM
DAVEANDPATTY
  • 8 POSTS
I've tried all the recommendations and no go. Engines still revs up and down all by itself. Could the problem be in the setting of the throttle positioner? When I unplug it, engine will rev up to about 2800rpms and hold steady. When I plug it back in, engine starts to rev up and down. Still stumped and I have donated. Thanks for any help.
Saturday, June 2nd, 2007 AT 10:11 PM
You mentioned the TPS have you tried testing it and initial adjustment
Sunday, June 10th, 2007 AT 11:45 PM
DAVEANDPATTY
  • 8 POSTS
Yes, I set the TPS per the factory specs and it also tested good. I even swapped out the throttle body and TPS from another running motor of the same and didn't change any settings. It did the same thing. Someone mentioned a possible vacuum leak. Can a vacuum leak actually cause the engine to rev up and then die down, over and over? I've had vacuum leak problems in the past with other repairs and they seem to only increase the rpms and not make the engine die down and then rev up again like this problem. Thanks for the reply; but I'm still stumped.
Monday, June 11th, 2007 AT 9:53 PM
Get the engine up to norm temp. now use WD-40 and spray around the throttle base,intake manifold/plenum. inspect all vacuum hoses,check the IACV,TPS,MAF sensor connector for a tight fit
Check the EGR and its vacuum solenoid operation-if its ajarred it will create a massive leak
Accelerator cable could be binding or stretch
Need more help comeback
Tuesday, June 12th, 2007 AT 4:29 AM
DAVEANDPATTY
  • 8 POSTS
Found a leak at the manifold gasket. Boy was I stumped about how a vacuum leak at the manifold could rev the engine up and down. I'll let you know how it goes when I get it back together.
Tuesday, June 12th, 2007 AT 11:07 PM
DAVEANDPATTY
  • 8 POSTS
I found the intake manifold gasket was bad. Apparently it was misaligned when originally installed and had finally burned out to a major leak. I replaced the gasket and all is fine. This vacuum leak also caused some error in the ECU not registering the O2 sensor malfunctioning when I would disconnect it. The engine never ran better. At least I now have all new sensors, a replaced ECU and a rebuilt throttle body that I really didn't need. Thanks for all the help and keep up the good work here. I'll definately will recommend this site to my friends.
Friday, June 15th, 2007 AT 12:20 AM
ARNIE22K1
Check the air injection at the exhaust and then the EGR gasket. If the inlet hose is blocked or leaking the idle will bounce. If blocked it will blow the EGR gasket.
Sunday, April 9th, 2017 AT 12:09 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,883 POSTS
Hey,
Great addition to this thread! Please feel free to help out on the site whenever it can add information that will help.
Best, Ken
Wednesday, April 12th, 2017 AT 6:29 PM
