Mechanics
NO START PROBLEM
1997 Toyota Tacoma
Engine Performance problem
1997 Toyota Tacoma 4 cyl Two Wheel Drive Automatic
Hi. I have a 1997 Toyota Tacoma 4 cylinder, automatic 2 wheel drive truck that won't start. If I spray ether into the air inlet, the truck will start and run till it runs out of ether. I have checked the fuses and changed the fuel pump relay. The electric fuel pump has been changed. This problem didn't just happen. Prior to this no start problem the truck would occasionly act up and not start but eventually would start. Now it doesn't start except with either. Please Help!Thanks in advance, Dave.
Eorcdave
October 22, 2010.
Check and test the circuit opening relay, the EFI relay and mass airflow meter
Rasmataz
Oct 22, 2010.
AD
