2CarPros - Car Questions & Answers
2005 Toyota Rav4 Repair Question
Topics covered: Rpm, Transmission, Engine.
Asked on June 10, 2010
2005 Toyota Rav4 No reverse on transmission
Transmission problem
2005 Toyota Rav4 4 cyl Four Wheel Drive Automatic
the problem is that putting the shift gear to R reverse, the car does not move. reving the car from 1000-3000rpm will not move the car, but once it revs to 3,000rpm and above. the car will suddenly launch to reverse. Driving the car in D is normal meaning it is shifting to all gears. I check individually the solenoid and it is working fine. I do the manual test which is unplugging the transmission wire and then start the engine and do the reverse and then there was reverse. Meaning all gear are working fine.
what could be wrong here?
No Answer Yet
