2001 Toyota Highlander
Air Conditioning problem
2001 Toyota Highlander 6 cyl Four Wheel Drive Automatic 150000 miles
I fjust had a new air conditioning compressor installed because the old one was wining. When I picked up the car the air coming out was not very cold so I bought a temperature probe and checked the temp. In the center vent. During a two hour period, the temp. Reached 45 degrees once and then it has not reached more than 75 tp 80 degrees with the outside temp. At 90 degrees. I took the car back to the mechanic and he said he put the correct amt. Of refrigerant in the car( 1 1/2 cans) and that the temp. Knob was not working which was causing the problem. The temp. Control knob has not been working for over 2 years and I have not had any cooling problems before now. I checked the low side coolant line and it was cool, but not cold and the high side one was hot. Does anyone know what the problem might be?
July 3, 2008.
Check out the related content below while we wait for the question to be answered by a professional mechanic.
