Mechanics
DRIVABILITY PROBLEMS
1998 Toyota Corona
Engine Cooling problem
1998 Toyota Corona 4 cyl Front Wheel Drive Automatic 63000 miles
Once my car engine reaches its operating temperature (generally about 200 degrees F, 95 degrees C) it begins to operate improper, problem with idle speed, and at some times reaches at 2000rpm at idle.
But when I unplug the ECT sensor connector the electrical fans activates. This causes the engine to drive normal again. The problem is that my fans will have to be active at all time.
Fernandot
February 11, 2009.
Check out the related content below while we wait for the question to be answered by a professional mechanic.
