Mechanics
IDLE UP VALVE
Toyota Corolla
My 1993 corolla has a little high RPM, but once the A/C is on the RPM is dropped below normal, that's what my friend say.
My question are the idle up valve and idle air control valve two different parts?
If they are different, which one cause the high RPM.
One more thing, is high RPM cause any problems for my car if I don't fix the problem. Thanks
Rock2001wwf
June 27, 2006.
Before you drop the rpm-check your Ignition timing then adjust the IACV to Specs.
Rasmataz
Jun 30, 2006.
AD
