Toyota Corolla Repair Question
Asked on December 15, 2006
Clutch Problems, HELP!
I recently installed a clutch on my 1995 Toyota corolla. I've never done one on this make/model, and I'm having problems. I installed the clutch and resurfaced flywheel and torqued them to specs, and new release bearing. I bolted it all back up, and the clutch wont completely engage it seems, it spins the cv axles but has little to no power at the wheels. The slave cylinder appears to be in functional condition, it was before we pulled the old clutch. Thanks.
Answer
Replied on December 16, 2006
Bleed the slave and adjust the free play-did you replace the pressure plate?
