2005 Toyota Corolla Repair Question
Asked on October 29, 2010
2005 Toyota Corolla DRIVE BELT
Engine Mechanical problem
2005 Toyota Corolla 4 cyl Two Wheel Drive Manual 200000 miles
I NEED TO CHANGE MY DRIVE BELT HOW DO I GO ABOUT IT
Answer
Replied on October 29, 2010
Hi MALAKIYA,
Here are the procedures.
FAN AND GENERATOR V BELT (1ZZ-FE)
REPLACEMENT
1. REMOVE ENGINE UNDER COVER RH
2. REMOVE FAN AND GENERATOR V BELT
a. Turn the drive belt tensioner clockwise to relieve tension on the belt, and then remove the belt.
b. Carefully return the tensioner to the unloaded position.
NOTE:
• Be sure to connect SST and the tools so that they are
inline when using.
• When retracting the tensioner, turn it clockwise slowly in 3 sec. or more. Be sure to not apply force rapidly.
• After the tensioner is retracted all the way, do not apply force any more than necessary.
