1998 Toyota Corolla Repair Question
1998 Toyota Corolla how do I change Belt - Serpentine by my
1998 Toyota Corolla 4 cyl Two Wheel Drive Automatic 90000 miles
I want to know what is the easiest way to change the belt with air condition unit by myself. Please show me the way to change it.
thankyou very much
Answer
Move tensioner pulley (arrow in picture) to release tension on belt, then remove belt.
Buy a good belt, Dayco, Gates, Goodyear, Toyota. Use brake clean to remove any contamination from pulleys, make sure pulleys are tracking properly.
I found the tensioner pulley, but I couldn't push it down like the photo shown. do I need some tool too release the tension?
A tensioner tool is available from most autoparts stores for rental.
Try a socket on a long ratchet.
thank you guys.. I finally got the belt out.
Great news.
Make sure to inspect pulleys and clean with brake clean. Brake clean dissolves grease, grime, coolant and leaves no residue.
im having a similar problem i got my pulley loose but it wont move so i cant get my new belt on.. what should i try
