Mechanics
WILL NOT TURN OVER
1996 Toyota Corolla
Electrical problem
1996 Toyota Corolla 4 cyl Front Wheel Drive Automatic
We have replaced the ignition switch and the main engine relay but it will not start what is wrong, it will click when the key is turned, the dash board will not light up but head lights are on and the door dings when it is open. What's next?
Octavia
October 16, 2010.
No crank at all/nothing/nada when key is engage to starting position
Could be the starter, starter relay, park and neutral switch/transmission position switch assuming the battery and connections are good. Note: If it doesn't apply disregard.
Rasmataz
Oct 16, 2010.
AD
