Idle speed problems
2003 TOYOTA COROLLA
74,235 MILES • 4 CYL • FWD • MANUAL
LAKIS
At idle engine revs go up and down between 1000 to 1500.Therefore engine works irregularly.
Dec 7, 2010 at 8:09 PM
DR LOOT
  • CAR REPAIR CONTRIBUTOR
  • 2,311 POSTS
CELICA, COROLLA, ECHO, MATRIX, RAV4 & TACOMA
Idle speed is controlled by Engine Control Module (ECM) and is not adjustable. Check idle speed with engine at normal operating temperature, transmission/transaxle in Neutral, parking brake applied, air cleaner and all air intake hoses installed, all vacuum hoses installed, electronic fuel injection system wiring connectors properly installed, ignition timing properly set, electric cooling fan off (if equipped), and A/C and all accessories off.
Start engine and warm engine to normal operating temperature. Shut engine off. Connect Toyota hand-held tester or scan tool to data link connector No. 3 at driver's side of instrument panel. See Fig. 75 , Fig. 76 , Fig. 86 and Fig. 87 . Hand-held tester or scan tool is used to read engine RPM.
Apply parking brake. Place transmission/transaxle in Neutral. Start engine and maintain engine at 2500 RPM for 90 seconds and then allow engine to idle while noting idle speed. Ensure idle speed is within specification. See IDLE SPEED SPECIFICATIONS table. Shut engine off. Remove hand-held tester or scan tool.
If idle speed is not within specification, check Idle Air Control (IAC) valve, wiring and Engine Control Module (ECM), and air intake system. See IDLE CONTROL SYSTEMS in SYSTEM & COMPONENT TESTING - 4-CYLINDER article.
Corolla
NOTE:Idle Air Control (IAC) valve is also referred to as Idle Speed Control (ISC) valve.
For Idle Air Control (IAC) system testing procedures, see Fig. 438 .
Fig. 438: Inspecting Idle Speed Control Valve (Corolla & Matrix)
Dec 8, 2010 at 5:10 AM
PRINGLE
  • 20 POSTS
Engine Performance problem
1997 Toyota Corolla 4 cyl Front Wheel Drive Automatic
hi there car pro guys i will know to know what cause this problem with my corolla car when i start it just dont idle i will have to rev it to keep the engine running an as soon as i come off the gas pedal it will cut out but if i drive it for a while an it warm up it will idle but cant remeber at how much rpm please help me you guys are the best thank you
May 7, 2020 at 11:18 AM (Merged)
MMPRINCE4000
  • 8,548 POSTS
Best thing to do is to remove the idle air control valve and clean the TB port, if it is very dirty, clean the entire TB (remove it). Use carb cleaner/degreaser, then a final spray of brake clean.
NESAN
  • 25 POSTS
I have a 4age silvertop, it has a problem with idling. When using power equipement(windows ,steering,heater, dash light...)RPM goes down. When driving in cold rpm goes to about 500 at stop. Please help solving the problem.
WRENCHTECH
  • 20,761 POSTS
You may have a bad IAC ( idle air control) but try cleaning the throttle body first. Remove the intake snorkel, have someone hold the throttle wide open for you and scrub the back side of the throttle plate and surrounding bore with an old tooth brush and some carb cleaner. Be sure to spray some into the small holes next to the throttle plate. That should help stabilize the idle. If it still has a problem, replace the IAC.
I have a 1991 Toyota Corolla 1.3L. The car run fines but it will not idle when cold. Once i leave the accelerator, it cuts off immediately. But when the car is warm, it idles but its like a rough high and low idle at times. I have tried carb cleaner spray and also a fuel liner cleaner you pour into your fuel tank but it didnt help at all.
KHLOW2008
  • 41,814 POSTS
Should be a problem with the IAC. Check to see if it is stuck in the closed position. When starting from cold, the engine idling speed should increase.
Hi sorry, I forgot to mention that i have a manual choke. I cant find the IAC valve.
KHLOW2008
  • 41,814 POSTS
Do you mean vehicle is equipped with carburettor? If yes and you have a manual choke, then you need to use it when engine is cold. A cold engine would need to run at a higher idling speed and with a richer mixture.
Yes i have a carburettor model vehicle. Thats the thing i cant understand. I never had to use the choke before. And with this problem that im having, even if the manual choke is pulled full, it still wont idle when cold.
KHLOW2008
  • 41,814 POSTS
When engine gets older and the weather gets colder, there would be a difference. When choke is pulled, does the engine idling increases? Have you checkd if the choke is opening correctly?
When was the last time a tune-up was performed?
no, the engine doesnt increase in idle when the choke is pulled. But it is opening and closing. I see it when the air filter is out. I did a tune up when this problem started
KHLOW2008
  • 41,814 POSTS
When choke cable is pulled, the idling speed should increase as the throttle plat would be opened. Check if the adjustment for the choke is correct.
