Mechanics
COOLING FAN WORKS WITH AC AND NOT HEAT?
1993 Toyota Corolla
Engine Cooling problem
1993 Toyota Corolla 4 cyl Two Wheel Drive Automatic 233000 miles
why do my cooling fans work with ac and not the heat?
Usmith
November 5, 2010.
Unplug fan control switch under dist. (White connector), turn ign. To on, fans should come on.
If not, test fan motor, if OK, then fan switch is bad.
Mmprince4000
Nov 6, 2010.
AD
