Mechanics
OIL PUDDLES AROUND SPARK PLUG EXTERIOR
1992 Toyota Corolla
Engine Mechanical problem
1992 Toyota Corolla 4 cyl Front Wheel Drive Manual 181000 miles
Oil is puddling around the exterior of the spark plugs #1 and #4. The spark plug is located within holes in the valve cover. What is causing this? Does it need to be fixed?
The engine began to miss, so I changed the spark plugs, wires, distributor cap and rotor. This corrected the missing. The oil puddling around one spark plug was probably touching the porcelain.
Once in a while one of the spark plug wires pops up about 1/4 inch above the top of the valve cover that it plugs. This doesn't seem to cause the car to miss.
AD
WayneRuss
March 12, 2010.
Change the spark plug tube seals, it can cause a miss.
Mmprince4000
Mar 13, 2010.
AD
