Mechanics
HOW TO REPLACE 92 TEMP CONTROL KNOB?
1992 Toyota Camry
The major symptom I'm having is that the air coming through the vents is consistently HOT--not warm or outside air temperature, but HOT, like the heater is running. I'm assuming there is something wrong with the hot/cold knob because it won't turn all the way. If I turn as far as it will go to the red/hot side, it does indeed get hotter than if I turn it as far as it will go to the blue/cold side. But the knob only moves about an inch in either direction, so it never actually reaches the end of the red or blue stripes.
So I'm guessing I have to replace the knob? Does that sound right?
So now I'm stumped on how to get the old one out. Any info would be most appreciated. Thank you!
Katefields
May 6, 2007.
Check out the related content below while we wait for the question to be answered by a professional mechanic.
AD
