Toyota Camry
Last night, way on the other side of town, I started my 90 Camry to return home and my oil light came on--which I've never noticed before, and I believe it stayed on the whole ride home. When I finally turned onto my street, the car shut off and quickly rolled to a stop. As it did, I heard a few clicks coming from the front of the car--the pistons locking up I assumed. All dash lights came on. I turned the key to try to start the car, and no action, just a click or two again. I pushed the car home.
I checked the oil today. It is full. My father and friend suspect either a broken/skipped timing belt or a bad oil pump. Both make sense to me. When I turned the key today, I heard my engine turning like normal, but no start.
I think that means the timing belt is set right, correct? How can I check the oil pump to see if it's working right? And is the engine likely damaged at all?
Thanks for any help!
January 24, 2006.
Check oil sending unit.
Jan 29, 2006.
