Mechanics
AIR CONDITIONING WORKS INTERMITTENTLY
2004 Toyota Camry
Air Conditioning problem
2004 Toyota Camry 4 cyl Two Wheel Drive Automatic 89000 miles
When I turn on the A/C initially it would work, then after a couple of minutes the coolness will stop. The compressor clutch is engaging, the refrigirant pressure is ok. Especially on a hot day, the A/C will work when first started, but will easily stop cooling.
Thank you for your help.
Toyotaroadrunner
April 24, 2008.
I think you have a faulty pressure switch
Legitimate007
Apr 24, 2008.
AD
