Cabin filters
ED.B
  • 2007 TOYOTA CAMRY
  • 4 CYL
  • 32,000 MILES
How do I replace the acc cabin filters in my Camry? Where are is it located? Will I need any tools? Thank You, Ed from Pittsfield, MA
Friday, September 25th, 2009 AT 12:08 PM
DOCFIXIT
  • 18,828 POSTS
Hi
Remove glove box
https://www.2carpros.com/forum/automotive_pictures/198357_Graphic_147.jpg
Push inward on sides of box let it hang down
Remove filter caes
https://www.2carpros.com/forum/automotive_pictures/198357_Grafic_3_42.jpg
Remove filter from case
https://www.2carpros.com/forum/automotive_pictures/198357_Grafic_4_14.jpg
When installing new use "up" mark
https://www.2carpros.com/forum/automotive_pictures/198357_Graphic_5_8.jpg
Friday, September 25th, 2009 AT 12:32 PM
YUKAMHON
  • 2004 TOYOTA CAMRY
When I use the defrost, my interior windshield fog up. I suspect it may be caused by the dirty cabin air filter. I had not changed it for four years, and 50,000 miles. I was told it is located near the compartment area. I follow the instruction from the box of the new filter, and could not drop the compartment box down as instructed. I am not doing it correctly. Please advise. Also, what tools do I need to get to the cabin air filter. I can use a better diagram if it is available. Thanks.
Stephen
Wednesday, March 10th, 2021 AT 6:14 PM (Merged)
If you can follow all the instruction/illustratiion you're home sweet home-Good Luck
https://www.2carpros.com/forum/automotive_pictures/12900_2004_camry_cabin_air_filter0_1.jpg
https://www.2carpros.com/forum/automotive_pictures/12900_2004_camry_air_filter1_1.jpg
https://www.2carpros.com/forum/automotive_pictures/12900_2004_camry_cabin_filter2_1.jpg
https://www.2carpros.com/forum/automotive_pictures/12900_2004_camry_air_cabin_filter3_1.jpg
https://www.2carpros.com/forum/automotive_pictures/12900_2004_camry_cabin_air_filter4_1.jpg
www. .com
Have a nice day/make sure you tell your friends about us.
JRB0001
  • 2003 TOYOTA CAMRY
  • 4 CYL
  • 57,000 MILES
Where is it, & how do I replace it?
AIR CONDITIONING FILTER REPLACEMENT
https://www.2carpros.com/forum/automotive_pictures/12900_af_2.gif
1.Open the glove box. Remove the screw with a Phillips-head screwdriver and slide the hook as shown.
2.Push each side of the glove box to disconnect the claws.
3.Remove the filter case from the filter outlet as shown.
4.Remove the filter from the filter case.
5.Inspect the filter on the surface. If it is dirty, it should be replaced.
Installation
Reverse removal procedure.
JJRB
  • 2003 TOYOTA CAMRY
  • 4 CYL
  • 60,000 MILES
Where is it located & how do I change it?
BLUELIGHTNIN6
  • 16,542 POSTS
It's behind the glove compartment. Open the glove box, remove the screws and slide the hook. Disconnect box claws by pushing inwards on sides of glove box and allow box door to hang down. Remove filter case from the outlet. Remove filter from the case and replace filter.
SINBADTIBURON
  • 2001 TOYOTA CAMRY
  • 6 CYL
  • 75,000 MILES
How I replace a cabin air filter in Toyota Camry?
Wednesday, March 10th, 2021 AT 6:15 PM (Merged)
  • 31,938 POSTS
Hi there,
Here is a guide to help you see what you are in for when doing the job with diagrams below to show you what it will be like for your car:
https://www.2carpros.com/articles/how-to-change-an-air-cabin-filter
Cheers
RUBONE625
  • 1997 TOYOTA CAMRY
  • 6 CYL
  • FWD
  • 185,000 MILES
Where is my cabin air filter located?
ZACKMAN
  • 4,202 POSTS
https://www.2carpros.com/forum/automotive_pictures/55316_97camrycabinfilter_1.jpg
https://www.2carpros.com/forum/automotive_pictures/55316_97camrycabinfilter2_1.jpg
https://www.2carpros.com/forum/automotive_pictures/55316_97camrycabinfilter3_1.jpg
https://www.2carpros.com/forum/automotive_pictures/55316_97camrycabinfilter4_1.jpg
CNA20086
  • 1998 TOYOTA CAMRY
  • 4 CYL
  • 4WD
  • 14,000 MILES
Where is the cabin filter located in my toyota camry 1998
Wednesday, March 10th, 2021 AT 6:16 PM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
The cabin filter is in the A/C evaporator housing which is located behind the center of the instrument panel. Below you will find some illustrations and a guide to help you find and change the filters
