Mechanics
REPLACING BELTS AND HOSES
2001 Toyota Camry
Engine Cooling problem
2001 Toyota Camry 4 cyl Two Wheel Drive Automatic
It's been 7 years. Want to replace main water hoses and engine belts. How many water hoses are there to replace? How many belts are there too replace?
Want to replace the radiator hoses. I assume the heater hoses should be replace too? I know about the serpentine and P/S belts. Are there any others that I don't know about that should be replaced now?
Thanks.
Revonoc
April 10, 2008.
How many miles do you have on it
I think you should be concern about the timing belt and the water pump check the idler and tensioner pulley
and you can do the other drive belts too
AD
BMRFIXIT
Apr 10, 2008.
It's got 55, 00 miles.
Revonoc
Apr 10, 2008.
I think the hoses should be OK
just look for any signs of weakness
you may have the belts replaced
BMRFIXIT
Apr 10, 2008.
Thanks!
Revonoc
Apr 11, 2008.
AD
