Mechanics
GAS PADEL PROBLEM
2001 Toyota Camry
Hi-2001 Toyota Camry - My car isn't moving much when I stepped the gas padel after I release the break when the car is stopped at traffic lights, the car then suddenly moved when hitting the gas little bit hard. What was the problem? Gas padel is free while running and no issues.
Thanks in advance
Paladugu
September 29, 2007.
Check the throttle Cable adjustment, open the hood and have somebody to check if opens all the way while you stepped the padel.
If not check the rubber boot on the cable to make sure that it didn`t slide and adjust it as necessary.
Fisherman
Sep 29, 2007.
