2001 Toyota Camry
Brakes problem
2001 Toyota Camry 6 cyl Front Wheel Drive Automatic 110000 miles
I have a 2001 Toyota Camry with 110,000 milles. Just replaced the front brakes, ie, pads, calipers and rotors. When I start the car, it has normal brake peddle, as I drive and the car warms up, the brake peddle stiffens and the brakes become very touchy. At 60+ miles an hour the steering wheel begins to shake. Also tires are new and balanced recently. No vibrations prior to brake job. Also bake lines were flused at 100k. Could this be a brake boster issue or and ABS sensor issue? Also, when I press on the brake peddle, I can hear a noise coming from or near the center consol. Any ideas on what it could be?
April 15, 2010.
Check out the related content below while we wait for the question to be answered by a professional mechanic.
