1997 Toyota Camry Repair Question
Asked on September 6, 2010
1997 Toyota Camry clanking noise with high rpm and low acce
Engine Mechanical problem
1997 Toyota Camry 4 cyl Two Wheel Drive Automatic 205006 miles
I have a 1997 toyota camry. The engine was runnign fine when I took it to shop for struts and mounts replacement. After picking up car, shop said it was very low on oil and the cap to radior was worn out. They as a courtesy placed oil and gave new radiator cap.
Engin started making a clacking or grrr noise when stepping on accelerator and vehichle would have high rpm in 1st and 2nd gear. Also battery died. Took back to shop and they replace battery but said the noise could be transmission or barrings/rod problem. This all seemed to happen suddenly need advise on what it really could be
