Mechanics
GAS SMELL
1995 Toyota Camry
Smells problem
1995 Toyota Camry Two Wheel Drive Automatic 165000 miles
Hello I have a 1995 Camry orig owner and I have a smell of gas more behind the drivers seat I have changed the fuel gasket under the rear seat and changed the fuel filter and have checked for leaks and I can't find anything. No pressure in gas cap when opened and as a added note near the cap itself there is no smell from right there.I cannot figure this one out if no leaks when I lift the rear seat and uncover the cover plate of the fuel pump cover I smell fuel under the car I just cannot not figure out where it is coming from.
Vcr1
April 25, 2009.
Check the charcoal canister could be saturated with fuel/vent hoses/vapor separator
Rasmataz
Apr 25, 2009.
AD
