1994 Toyota Camry overheating
PAULMOATS46
  • 31 POSTS
Ok you boys, you said you would stick with me till the end, this is the end. Gladly return my 2.00
Thursday, May 13th, 2010 AT 10:23 PM
You've said the head and block is cleared and there's no coolant moving thru the engine the water pump function is to pump coolant thru out the engine-the coolant will not circulate on its. Now request for your $2.00 thru normal procedures and good luck-Remember I have a life too.
Sunday, May 16th, 2010 AT 4:23 PM
THIS IS MIKE
  • 686 POSTS
We are sorry we could not help you. Your donation has been refunded.
Sunday, May 16th, 2010 AT 8:54 PM
PAULMOATS46
  • 31 POSTS
Thank you for refund
Sunday, May 16th, 2010 AT 9:52 PM
THIS IS MIKE
  • 686 POSTS
You are welcome. We appreciate our members and stand behind our promise that if we can't help solve your problem we will return any donation. Our team of technicians really do try hard to help everyone we can.
Monday, May 17th, 2010 AT 1:03 AM
2CARPRO JACK
  • 11,533 POSTS
Regardles of the price of the block test, that is where this is headed. Most times when a cooling system cant keep up when driving, itis because the cooling system is being pumped full of exhaust, thus it displaces the coolant and causes the overheating/overflow of coolant. This can even cause the water pump to cavitate, which impedes the flow of coolant and causes the t-stat to open and close since it cant react to air, only fluid
Monday, May 17th, 2010 AT 12:01 PM
PAULMOATS46
  • 31 POSTS
Thank you, I don`t want to argue or make you mad but I understand cavitation very well I worked on very large water pumps in the inviromental deparment of a automotive foundry for 32 years. Can you tell me how the test will pin point the problem or am I going to have to tear it down, like I said? PLEASE READ ALL MY POST.I FELL LIKE I`AM BEATING A DEAD HORSE. It looks to me like I will just be throwing 70 dollars away for nothing
Monday, May 17th, 2010 AT 4:28 PM
2CARPRO JACK
  • 11,533 POSTS
You are correct in that the test isnt 100%, but then again nothing really is. LOL I understand the kit is pricey, call around to see what a shop would charge to do it, sometimes it is less than the kit.A 4 or 5 gas analyzer will do the same thing, and a little more accuratly, but most places wont use their emissions equipment for doing that.I have seen many head gaskets do exactly what you describe. Since you have replaced evey part of the cooling system, it honestly looks like the head gasket is the direction you are headed in. Toyotas dont tend to crack heads either, not to say it isnt possible, but I cant recall seeing it
Monday, May 17th, 2010 AT 11:17 PM
PAULMOATS46
  • 31 POSTS
It would not matter if that test cost 15 cents. Its useless. You have just told me more in your last post than all the others togather
Tuesday, May 18th, 2010 AT 12:39 AM
2CARPRO JACK
  • 11,533 POSTS
I dont usually deem diagnostic tests useless, especially when the cost is considered for the repair, it is best to be sure of the diagnosis.
Tuesday, May 18th, 2010 AT 8:12 AM
PAULMOATS46
  • 31 POSTS
Could you tell me what the benifits of that test would be
Tuesday, May 18th, 2010 AT 2:06 PM
2CARPRO JACK
  • 11,533 POSTS
To determine if there is indeed exhaust present in the cooling system.I understand your point of having replaced everything else and that all things point to a bad head gasket, but when you are in a shop environment, you need to be able to tell the customer that you did all diagnostics and this is whats wrong. Honestly in a shop, all other parts wouldnt have been replaced first, so the test wouldnt seem like such a waste of time/money
Wednesday, May 19th, 2010 AT 7:47 AM
PAULMOATS46
  • 31 POSTS
Ok that was a great explanation just one last question if I brought the car to you explained everything I did and told you I wanted you to block test it and you find nothing wrong what would be your next move
Wednesday, May 19th, 2010 AT 12:23 PM
2CARPRO JACK
  • 11,533 POSTS
Would still suggest a tear down based on what is happening and the fact that the test isnt 100% as I told you before.
Thursday, May 20th, 2010 AT 8:06 AM
PAULMOATS46
  • 31 POSTS
Would still suggest a tear down based on what is happening and the fact that the test isnt 100% as I told you before.) No where in this post have you suggested a tear down. That has been my whole point in this discussion, that the test would not pin point the problem and you would have to tear it down and look her over. Thank you for your time, wisdom, and patiance
Thursday, May 20th, 2010 AT 2:10 PM
2CARPRO JACK
  • 11,533 POSTS
You're welcome, but I said that the test isnt 100%, but by not testing yours we will never know if it would have shown positive. There are always possibilities for everything
Thursday, May 20th, 2010 AT 10:41 PM
PAULMOATS46
  • 31 POSTS
Well there`s a possibility I will win the lottery and if I do you guys can expect a donation if you will tell me what you will do if the test is positive and what you will do if it`s negative
Thursday, May 20th, 2010 AT 11:22 PM
2CARPRO JACK
  • 11,533 POSTS
Im done with the point/counterpoint discussion. Have a nice day and thanks for using 2Carpros. Com
Friday, May 21st, 2010 AT 8:07 AM
PAULMOATS46
  • 31 POSTS
Aw, shucks I bet you tell all your cusumers that. Btw you didn`t tell me good luck in the lottery. Don`t you want me to win?
Friday, May 21st, 2010 AT 2:37 PM
2CARPRO JACK
  • 11,533 POSTS
Best of luck in the lottery and all other ventures, and no, I dont tell any of my customers that. Have a nice day
Saturday, May 22nd, 2010 AT 8:17 AM
