Serpentine belt replacement?
MONSANTJ
  • 1999 TOYOTA CAMRY
  • 4 CYL
  • FWD
  • 127,000 MILES
I have a 99 Toyota Camry and it has a noise almost close to helicopter sound coming from somewhere or something around the drive belts. Its almost a sound when the engine is idling too high. It can also sound as if something is loose but I really cant figure it out. Im assuming that the drive belts may need to change but not sure. Any ideas what it could be?
Thanks
JJ
Friday, December 26th, 2008 AT 12:08 PM
ZACKMAN
  • 4,202 POSTS
It is coming from one one the pulleys. Overtime, the bearings inside the pulley can and do go bad, and that is what happens to you. If you are doing the work yourself, remove the serpentine belts, and spin each pulley, one at a time. You will hear the bad sounds way different than the others..
This guide can help you see how the change the serpentine belt.
https://www.2carpros.com/diagrams/toyota/camry/1999
I would replace the belts, too.
Saturday, December 27th, 2008 AT 4:28 AM
CURTIS27
  • 1997 TOYOTA CAMRY
  • 4 CYL
  • 225,000 MILES
Will I break down if my serpentine belt or air conditioner belt brakes?
Tuesday, July 21st, 2020 AT 11:37 AM (Merged)
WRENCHTECH
  • 20,757 POSTS
Yes, you will eventually. You will immediately lose your power steering and alternator. That will run the battery down until the car dies. This will happen quicker at night.
DESERTROSE
  • 12 POSTS
  • 1997 TOYOTA CAMRY
I have camry with 190k miles I was planning to change the timing and water pump from Toyota dealer. My Question is that after changing my timing belt and water pump is there any problem which can come up after installing means like Tramission, Heating problem or any other because currently everything works great.
Please drop advise so I can take action.
Thanks in Advance and Do reply who read it.
There shouldn't be a problem with the tranny and heating after the installation if performed correctly by the numbers step by step
MICKMILLIE12
  • 1995 TOYOTA CAMRY
  • 4 CYL
  • 250,000 MILES
How do you adjust the drive belt and if my car contunes to make nose in the front passenagers wheel than what else can it be than. It wasn't making the nose when I first got it but once I changed the timing belt and then put everything back together then it started to make the nose so I dont think I need a new belt.
Tuesday, July 21st, 2020 AT 11:38 AM (Merged)
BMRFIXIT
  • 19,053 POSTS
If belts old then should be replaced
check this link has picture shows you how and or where the adjuster
https://www.2carpros.com/car_repair_information/tec_info/1995/toyota/camry/1995_toyota_camry_drive_belt_routing_diagram.htm
RAUL RIZZUTI
  • 8 POSTS
Your car needs a new belt
JAYYOUNG
  • 1995 TOYOTA CAMRY
  • 187,000 MILES
My power steering belt is worn, can I drive without one? Just in case it breaks on my way to get the replacement. Also, should I change anything else? Water pump. Pulleys, accessories, tensioners? Not a mechanic but I really need help on this one. Thank you and your feedback will be greatly appreciated.
  • 108,164 POSTS
Don't worry, I'll help. I need to know something. Is there only one belt or does the power steering have its own belt? From what I can see on our homepage, there is a seperate belt for the PS. Let me know.
JAYYOUNG
Yes the PS has its own belt separate from alternator.
  • 108,164 POSTS
Okay. If the power steering belt breaks, you will lose power assist at the steering wheel. In other words, it will get hard to turn the steering. As far as driving it like that, you will need to be careful, but it won't damage anything unless the belt hits something when it comes apart.
How bad is the belt? It really takes a lot for them to break.
JAYYOUNG
Starting unravel.
JAYYOUNG
Thank you again!
  • 108,164 POSTS
Jay:
If it is starting to unravel, you really need to get it replaced. As I mentioned, if the belt breaks, it won't cause any damage to the car, but it will become very hard to drive.
Please be careful.
MKBLAKE46
  • 1993 TOYOTA CAMRY
  • 6 CYL
  • 92,000 MILES
I had a water pump and timing belt put on 3 months ago. After these were put on I had to start warming my car up before it would go past 5 miles an hour. I never had to do this before. Now when I slow down for a car to turn then step on the gas to take off again it chugs or hesitates 2 or 3 times then it goes. Is this just a coincedence that this started after they worked on my car or did he put something in wrong?
MASTERTECHTIM
  • 4,749 POSTS
It sounds like the timing is off. Id bring it back and have them drive it. If the belt is off a tooth it will do as you are describing. Let us know how you make out
CLAVIS
  • 1992 TOYOTA CAMRY
Other Category problem
1992 Toyota Camry Engine Size unknown Two Wheel Drive Automatic 162378 miles
how do you tighten the fan belt to eliminate noisei
Tuesday, July 21st, 2020 AT 11:39 AM (Merged)
  • 31,938 POSTS
Hi there,
Back off pivot bolt at top off alternator, back off adj pinch bolt 12mm this is the one through adj arm onto alternator. Adj alternator with long adjuster bolt, (below pinch bolt) Do not over tighten, tighten pinch bolt and pivot bolt.
Mark (mhpautos)
EMEDAVE
  • 1991 TOYOTA CAMRY
  • 6 CYL
  • 76,300 MILES
Where is and how do you loosen the pivot bolt on the power steering pump? How do you get to it?
