1993 Toyota Camry Repair Question
Topics covered: Thermostat, Alternator, Coolant.
Asked on August 16, 2010
1993 Toyota Camry thermostat
1993 Toyota Camry 6 cyl Front Wheel Drive Automatic 169,23 miles
where is the thermostat located and how do i replace it?
Answer
Replied on August 16, 2010
Service and Repair
On models with coded audio anti-theft systems, refer to Technician Safety Information for code procedures.
Drain engine coolant.
Remove water inlet pipe to alternator adjusting bar attaching bolts, then remove water inlet pipe and O-ring.
Disconnect water temperature sensor electrical connector.
Remove water inlet from water pump, then thermostat and gasket.
Reverse procedure to install. Reset audio anti-theft system, if necessary, as outlined under Technician Safety Information.
http://www.2carpros.com/kpages/auto_repair_manuals_alldata.htm
