Mechanics
AM2 FUSE KEEPS BLOWING OUT
1992 Toyota Camry
Electrical problem
1992 Toyota Camry 4 cyl Front Wheel Drive Automatic
I took my car thru a carwash. Parked it. Now it will not start. I checked all fuses and found one blown out (am2-30A) Replaced it and it blow out again once I turned the key to start. Fuse is located under the hood.
Bless u for your help!
SANDRAQ
March 3, 2009.
You have a direct short to ground on the black and orange wire when it leaves the ignition switch Ign2 to the resistor/injectors
Rasmataz
Mar 3, 2009.
