Mechanics
WATER PUMP LEAK
1991 Toyota Camry
Engine Cooling problem
1991 Toyota Camry 4 cyl Two Wheel Drive Automatic
my water pump is leaking from a hole right in the front. It looks to have threads, like a bolt or seal.I'm wondering if this is an 'easy' fix. Like sealant or a bolt? And if not will I need to lift the engine and remove the timing belt to replace the water pump?
ADDITIONAL INFO PLEASE.
is this a driveway job. Or will I need a shop?
G13
August 17, 2009.
Pump no good need to be replace
also I would replace the timing belt too
BMRFIXIT
Aug 17, 2009.
AD
