1991 Toyota Camry bad fuel pressure
THOMASTHOMAS1
  • 1991 TOYOTA CAMRY
  • 6 CYL
  • FWD
  • 202,000 MILES
I have rebuilt a dozen engines in my life and am a fair shade tree mechanic. My car occasionally sounds and feels like it is running out of gas. It sputters and once in a while stalls but starts again like nothing has happened. Sometimes when I stop at a stoplight and start to go it stumbles for a second or 2 and then moves right a long or just quits but restarts immidiately and off we go. In the mornings it is hard to start - sounds like it is trying to pump the gas and eventually starts and runs fine till it starts it's occasional sputter problem. I replaced the fuel pump, filter, and fuel regulator but no difference in the problem. Yesterday when I pulled off the fuel rail regulator there was no pressure. I talked to a couple of mechanics at the local Toyota dealer and they had no answer but Toyota dealer wants $90+ to diagnose my problems. I'm stumped. Any ideas?
Saturday, November 28th, 2009 AT 11:58 AM
  • 31,938 POSTS
Hi there,
Thank you for the donation, the first thing to do is hook up a fuel pressure gauge and run the engine, check the pressure readings with the Toyota specs, let me know what you get.
Mark (mhpautos)
Saturday, November 28th, 2009 AT 5:21 PM
THOMASTHOMAS1
  • 8 POSTS
There is no place to attach a fuel flow meter. I will have to cut a hose and splice in the gauge. Lets assume I have intermittent low fuel pressure. I've replaced everything from the gas tiank to the fuel rail. What else can it be?
Monday, November 30th, 2009 AT 7:59 PM
  • 31,938 POSTS
The fuel pressure regulator will give this problem. And a leaking injector will drop static fuel pressure as well.
Mark
Monday, November 30th, 2009 AT 8:04 PM
THOMASTHOMAS1
  • 8 POSTS
Thanks. I'll hook up a fuel pressure gauge tomorrow and ducktape it to my windshield and see what happens when the engine stumbles. It's late - take the rest of the day off!
Monday, November 30th, 2009 AT 9:06 PM
  • 31,938 POSTS
O let me know how you get on, it's only 2 in the afternoon here, lots more to be done yet,
mark
Monday, November 30th, 2009 AT 9:15 PM
THOMASTHOMAS1
  • 8 POSTS
I assume I am replying to your last reply - can't tell from this screen. I spliced a fuel pressure gauge between the fuel line from the tank and the fuel filter and drove the car. The gauge read 7 inches of something and remained steady even after the car warmed up and occasionally started to act like it was running out of gas. Apparently it isn't a fuel problem. I don't think it's a spark plug because it has stalled once or twice and one spark plug can't do that. I suspect the distruibutor cap and rotor. What do you think?
Thursday, December 3rd, 2009 AT 11:47 AM
THOMASTHOMAS1
  • 8 POSTS
Attached is a photo of the cheap Chinese vacuum/fuel gauge with numbers all over the place and no instruction in the pamphlet in 6 languages. the needle initially sat at 0 until I used the gauge and now it sits on 2 with no adjustments. When the gauge is hooked up to the car and running the needle runs counterclockwise to the just south of ther big number 6 on the left hand side of the gauge. I assume that is showing 22 on the inside gauge. I don't know what that means. My Toyota manual says "with the vacuum sensing hose attached . . . 33-37 psi. Does that mean I have low pressure? What would cause that? I have replaced everything in thee fuel line.
https://www.2carpros.com/forum/automotive_pictures/440856_File0009_1.jpg
Thursday, December 3rd, 2009 AT 12:24 PM
THOMASTHOMAS1
  • 8 POSTS
I finally got a fuel pressure gauge that works and set it up so I could read it while driving thee car. It read 40-50lbs depending on acceleration and did not drop when the car sounded like it was running out of gas. Since it has completely stopped a couple of times in the past I am ruling out a bad sparkplug and guessing I should change the distributor cap and rotor. I have never seen the check engine light come on. Whadaya think?
Monday, December 7th, 2009 AT 3:57 PM
  • 31,938 POSTS
Well it looks as if the fuel system is ok, I think that we are having ignition problems, coil may be breaking down under load, this will not throw a code either.
Mark (mhpautos)
Monday, December 7th, 2009 AT 7:27 PM
THOMASTHOMAS1
  • 8 POSTS
Someone else mentioned the coil. I think I'll cruise over to PullAPart and get one of everything. This ranks high among all the mysteries I've had as a shadetree mechanic since I was 14 years old. Make me an offer and the car is yours.
Monday, December 7th, 2009 AT 7:34 PM
  • 31,938 POSTS
LOL. Will you pick up the air fair from Aust so I can come and get it. Second thoughts after you get this sorted you should have a great little car. Let me know how you get on.
Mark.
Monday, December 7th, 2009 AT 7:39 PM
THOMASTHOMAS1
  • 8 POSTS
I stopped by my favorite junkyard to pick up an ignition coil but there were none available.. Apparently a common problem. I ordered one on the Net and installed it in 10 minutes and my problems are solved. My fuel problem was an electrical problen. I am even more in love with my old Honda Civic now because it doesn't throw problems in disguise at me, point in one direction instead of the right direction, hide engine light notices, and all the other over-engineered bs that my Camry does. Thanks for your help.
Sunday, January 3rd, 2010 AT 5:08 PM
