1990 Toyota Camry Repair Question
Topics covered: Fuse, Distributor, Spark.
Asked on August 16, 2008
Wiring diagram
Electrical problem
1990 Toyota Camry 4 cyl Front Wheel Drive Manual 178954 miles
My car recently i had jumped with a piece of metal my EFI fuse and had been driving it about 180 miles and all of a sudden it just had no power and burnt out a couple fuses i replaced all the bad fuses and all my fuses are working now but my car will still not start and is not getting a spark for some reason i replaced the cap and rotor brand new less then 300 miles on them was wondering if you knew where i should look to figure out why its not getting a spark if theres maybe a wiring diagram i could look at.
Answer
Replied on August 16, 2008
Check the ignition fuse/look for power at the coil/test the resistances of the distributor pick-up coil/ignitor-
ignition fuse is getting power,
How would i check to see if the coil is getting power to it?
Remove the distributor cap and test coil positive terminal to ground-see below
