Mechanics
TOYOTA CAMRY AXLE PROBLEM
1987 Toyota Camry
1987 Toyota Camry
How do I replace the back up light switch? When I put it in reverse the lights don't come on. The bulbs are fine.
SonnyS
November 6, 2008.
Hello - sonnys
I have provided the location of the switch for both manual and automatic. There are not specific instructions therefore it once you see where it is at, it is as simple as disconnecting the connector, removing a bolt then removing and replacing the component.
Also, please make sure so that we provide the correct information you provide all of the data for your vehicle, if it is a sedan or wagon, specific engine size by liter and the 8th digit of your VIN. If it is automatic or manual and how many miles are on it.
Manual
http://www.2carpros.com/forum/automotive_pictures/248015_87839552_1.jpg
Automatic
The backup light switch is incorporated into the Neutral Start Switch, which is attached to the transaxle.
http://www.2carpros.com/forum/automotive_pictures/248015_87839550_1.jpg
ImpalaSS
Nov 6, 2008.
AD
