Mechanics
THE CAR WON'T START OR CRANK.
1993 Toyota Corolla
My Toyota with a 4A FE, 16valves twin-cam is neither cranking nor starting. No lights on the dashboard.I replaced the Timing belt and the high tension cables. Please help me with the procedure that I should follow to rectify this problem. The headlights are working perfectly.
Govaton
October 2, 2013.
Have you checked the ignition switch? Have you checked the main fuses under the hood?
Thank you in advance, iam going to check.
AD
Govaton
Oct 2, 2013.
Let me know what you find.
AD
